I have a Comfort II PCB with Firmware ULT 5.045 and a UCM06/ETH02 with firmware 6.xxx and I wish to use the iPhone app. Can you confirm that the necessary upgrades are as follows:
Upgrade UCM to latest firmware
Buy MPU01 and upgrade Comfort II to latest firmware
Also, what are the benefits in upgrading to ETH03?
Thanks for your help
Threads: 885
also the ETH03 has 2 ports for connection at the same time
Thanks Julian - I suppose if I am upgrading I might as well get all the latest hardware.
Thanks slychiu - what sort of scenario would require 2 ports?
If I decide to go to ETH03 should I replace the UCM as well? The one I have at the moment has UCM PC01-066A and P049671 on it.
Threads: 62
ComfortClient on the one port and iPhone app on the second.
PS. You only need to upgrade the Eth02 to Eth03 module.
The hardware has arrived but I see the ETH03 needs UCM firmware 7.028 or above so I presume I need to upgrade this before installing the ETH03. The current setup of UCM06/ETH02 seems to be working fine: I can Buzz the ETH using DS Manager and see the green and orange lights flash and I can execute responses and download configuration to Comfort using Comfigurator. However, when I use the Modules tab and right click on the UCM and select \"Download Firmware Upgrade\" I get \"Failed to connect to UCM - please check the UCM Connection Settings\". How should I proceed?
Thanks for your suggestion CytechMartin. I downloaded the file and tried an update but got \"Firmware upgrade encountered errors\". I shut down Comfigurator, turned off the windows Firewall and tried the upgrade again and it worked OK. Was this a coincidence or could the firewall be blocking things?
Slychiu - when I right click on Controller and select Download Firmware upgrade I get \"Module scanning requires Comfort version >= 5.154 and UCM version >= 5.171. Please add manually ....\". When I right click on UCM01 and select Download Firmware upgrade I get the message \"Failed to connect to UCM - please check the UCM Connection Settings\". In both cases the \"Check for firmware upgrade\" is greyed out in the context menu.
Threads: 885
We have not found any problem with Windows firewall so far
The module scanning may not have returned the correct results the first time
So is everything OK now?
