The date for keypad is change
The date for keypad is change i mean when setting in 22/Nov/14 after shutdown the date return in 29/Aug/13  also in time   where is problem
Note not connected battery
If the battery is not connected then the date and time are not  saved
You have  to connect a battery
Comfort is not designed to be switched off and on like a computer. It is always left on 24 hours a day
You can also install the UCM/ETH03 which synchronises with an Internet Time server. This will always keep the correct time
