Control Keypad Back Light with response
Would it be possible to control the keypad back light with a Comfort response. I would like to link the back light to a PIR so when a user passes the keypad lights up. This would save the user needing to push a button to check the time etc when \"always on\" is not desirable. It may also be the in night the keypads are lit and in the day they are not.
I second that. Perhaps even use a PWM signal to set the backlight brightness between 0 and 255.
And while you are at it, give the user an option between 12H and 24H modes.
Ingo
perhaps an action can be added to control backlight
For AM/PM, this selection is possible on KP06, not KP04
Kp04 is not firmware prgrammable so that cannot be changed annyway
Perhaps a future version of the KP04 controller chip as the embedded firmware surely is updatable at the time of manufacturing? Unless you bought a gazillion chips all preprogrammed :-)
a future version may have the upgrading feature but the existing KP04s will not be uogradable
I have the KP06 so look forward to an update :-)
Thanks, I would buy a few new KP04\'s when available, they are rock-solid and work perfectly.
a new action 156 has been added in Ult 7.061 beta, see http://www.comfortforums.com/view_topic.php?id=3935&forum_id=79
This action can turn on of off the backlight of any keypad ID, or of all keypads
[user=26]Daylehouse[/user] wrote:
Quote:I have the KP06 so look forward to an update :-)
Note that you do not need the KP06 to work with action 156. That action will work for all keypads
Kp06 already has the setting for AM/PM or 24 hours  display in settings
But I dont think allowing variable dimness of the backlight will be considered  in KP06 or KP04, as there will be too much work for insufficient benefits
ident wrote:
Quote:a future version may have the upgrading feature but the existing KP04s will not be uogradable
Any chance of adding a proximity sensor to the future version? This might result in less code to handle the back light from installers Smile
