Threads: 1
Installation:- Comfort II with the latest firmware 7.057 - UCM/GSM2 with the latest firmware 7.029
Problem:- SMS command successfully executed and acknowledged by the system with the right (XXXX) - OK message.- unfortunately after each command I receive an additional SMS with the message \"Invalid Command\" SMS which means extra costs although I understand that the GSM4 will reply with the status or help after the command.
Is there a way not to receive those extra SMSs (additional cost) for older than GSM4 UCMs?
Cheers,GIMI
Threads: 476
Can you run the Bus Monitor from Tools before you send the SMS and save it then send it to support@cytech.biz
Threads: 2
Is there a solution to this problem already?
Whenever I sent a Home Control SMS message to Comfort I also have the same problem where the message \"Invalid command\" is received via SMS even though the Home Control command is executed with no problems.
For example I send from mobile phone to Comfort the following SMS
(4010)
then I receive
(4010) - OK
and then a second SMS message is received on the phone
\'Invalid Command\'
My firmware versions are the following:
- Confort II Ultra 7.059(beta) - with 7.057 I also had the same problem
- UCM/GSM 7.029 ( I believe my GSM module still is GSM01)
Threads: 476
08-28-2014, 06:36 AM
(This post was last modified: 08-28-2014, 06:51 AM by ident.)
we have not heard from the other user about the result of the Bus monitor for his problem
Can you run Bus Monitor in Tools Menu, then send the SMS
The Bus monitor may tell us why the extra Invalid message was sent by Comfort
Threads: 2
I have just sent to support email address the bus monitor extract as well as the project file. Nevertheless see bellow also this same Bus Monitor output ( slightly trimmed)
11: 46: 40: 529 ----< 03 22 3F 32 36 36 34 31 32 02 <--->\"?266412
The analog vale of Slave 02\'s input 26is 64
11: 46: 47: 904 ----< 03 22 3F 32 36 36 35 31 31 02 <--->\"?266511
The analog vale of Slave 02\'s input 26is 65
11: 46: 50: 873 ----< 03 13 7C 30 37 30 31 33 33 33 35 33 31 33 39 33 33 33 31 33 36 33 39 33 34 33 30 33 32 33 38 46 33 02 <--->|0701333531393331363934303238F3
GSM caller ID for verfication
11: 46: 50: 904 ----< 03 13 7C 38 35 30 31 30 37 45 31 02 <--->|850107E1
GSM caller ID is valid
11: 46: 50: 935 ----< 03 13 7C 30 38 33 34 33 30 33 31 33 30 41 31 02 <--->|0834303130A1
GSM nemu command
11: 46: 50: 967 ----< 03 12 63 30 32 30 30 30 39 30 31 37 43 02 <--->c020009017C
Send data to Ucm 02 RS232 port
11: 46: 51: 764 ----< 03 22 3F 32 36 36 34 31 32 02 <--->\"?266412
11: 46: 52: 248 ----< 03 22 3F 32 38 36 34 31 30 02 <--->\"?286410
The analog vale of Slave 02\'s input 28is 64
11: 46: 54: 404 ----< 03 13 7C 38 34 34 39 36 45 37 36 36 31 36 43 36 39 36 34 32 30 34 33 36 46 36 44 36 44 36 31 36 45 36 34 34 34 02 <--->|84496E76616C696420436F6D6D616E6444
Create tect message
11: 46: 54: 451 ----< 03 13 7C 38 33 33 39 33 33 33 31 33 36 33 39 33 34 33 30 33 32 33 38 31 31 02 <--->|8339333136393430323811
Send SMS to number
11: 46: 55: 607 ----< 03 22 3F 32 36 36 35 31 31 02 <--->\"?266511
11: 46: 59: 248 ----< 03 13 7C 30 36 30 31 36 37 02 <--->|060167
GSM SMS sent
11: 46: 59: 326 ----< 03 22 3F 32 36 36 34 31 32 02 <--->\"?266412
11: 46: 59: 779 ----< 03 22 3F 32 38 36 33 31 31 02 <--->\"?286311
The analog vale of Slave 02\'s input 28is 63
11: 47: 02: 482 ----< 03 22 3F 32 36 36 35 31 31 02 <--->\"?266511
11: 47: 02: 795 ----< 03 22 3F 32 38 36 34 31 30 02 <--->\"?286410
11: 47: 03: 373 ----< 03 13 7C 30 35 30 33 36 36 02 <--->|050366
GSM network stregth of03
11: 47: 04: 889 ----< 03 22 3F 32 35 36 33 31 34 02 <--->\"?256314
The analog vale of Slave 02\'s input 25is 63
11: 47: 05: 123 ----< 03 22 3F 32 36 36 34 31 32 02 <--->\"?266412
11: 47: 05: 185 ----< 03 40 41 30 30 30 31 30 30 30 30 37 42 02 <--->@A000100007B
Request All Keypad turn off LED1,turn on LED2, turn off LED3, turn off LED4
11: 47: 05: 357 ----< 03 13 7C 30 35 30 34 36 35 02 <--->|050465
GSM network stregth of04
11: 47: 05: 576 ----< 03 22 3F 32 38 36 33 31 31 02 <--->\"?286311
Threads: 476
Thanks, for the Bus monitor and cclx files. we have found the cause of this problem
It is actually a bug in the Comfort firmware, that happens only when the Control Menu has no feedback. Instead of not sending any reply, it sends \"Invalid Command\"
This will be fixed in the next firmware. However by not using the control menu feedback you may be missing out on one of the useful features of the UCM/GSM
The Control Menu has a Feedback Type and Feedback Register for each control key
Eg, if you are controlling KNX eg 1/1/5 group address, you can map a counter to that address so that the state of 1/1/5 is mapped to the counter
In Control menu feedback you can assign Feedback Type = counter and Feedback Register = Counter number.
This allows you to check for the status of the KNX device when you send an SMS eg (401) to check status or when you send (4011) to control the device. It will reply with (401) On or Off to show the actual status
However I have also noticed a potential problem with the programming of your control menu
For your control menu actions, you have used 0 for On and 1 for On. This will give the opposite status as our aplications like GSM and smart phone apps assume that 0 is always for 0ff and 1 is for On
This does not affect you if you do not use any feedback or the Comfort app, but it would be best to use the conventional meanings of 0 and 1
Threads: 872
02-01-2018, 06:34 PM
(This post was last modified: 02-01-2018, 06:35 PM by slychiu.)
Updated 1/2/2018
ULT 7.077 introduced the same \"bug\" ie if no feedback in the control menu, after sendin a command eg (4001) and the control is executed, there is a reply \"Invalid command\"
The next firmware (> 7.137) should fix that
It is always Better to have feedback
