Interfacing with Axis Network Camera
I would like to interface Comfort with an Axis M3024-LVE Network Camera as follows:
Axis output -> Comfort input
This will enable Comfort to respond to the camera\'s motion detection.
Comfort output -> Axis input
This will enable Comfort to trigger camera recording when specific events occurs.
I have attached the wiring diagram for the camera connections.
As I understand, the Axis input requires pins 1 and 3 to be bridged. As Comfort provides open-collector outputs, will I need a relay module to achieve this?
Regarding the Axis output, I am a little unsure. Can pins 1 and 4 be connected to a Comfort input as is?
For Comfort Output to Axis Input, you need a relay to connect pins 1 and 3
That is the safest way, using RLY01 module. Comfort output is open colector, so it will pull pin 3 to about 1v which may or may not be low enough to trigger the axis
For axis output to Comfort input you can probably connect pin 4 direct to a Comfort Input and connect pin 1 to the zone common. according to the schematic they provide a dry contact output. Program the zone as Switch Normally Open zone type
Thank you. I have just ordered the RLY01 relay module and ACC-PLATE02 mounting plate.
I will update to confirm when it is working in case anyone else is looking to do the same.
Just a quick update:
This is working perfectly using the RLY01 for the Axis input, and a standard Comfort input for the Axis output.
Thanks again for your help with this.
Thanks for the update
I have moved this to \"Faqs - Technical\" forum to facilitate easier searching and access for others looking for a similar interface
