During a current upgrade I have swapped over the main Comfort PCB.
Before the swap I had2 keypads a KP06 (ID1) and a KP04 (ID2). Both are physically wired to the same connector block.
After power on and write config to Comfort, all UCMs are OK and so is Keypad 1 but it says it cant find Keypad 2 on scan.
Physically looking at the Keypad it is powered on and the LCD shows messages OK. Try to sign in on it and it bleeps as code is entered but after that is silent. I\'m guessing because the # of KP\'s is 1 in config.
Well I cant change this unless the scan finds it as it\'s greyed out these days.
HELP!!!
I suspect it\'s due to the way these devices are scanned these days?
11-19-2013, 01:22 PM (This post was last modified: 11-21-2013, 07:25 AM by ident.)
Old keypad firmware cannot be scanned if they are not polled ie the nmber of keypads is 1 but your keypad ID is 2
The simple way to fix this is to add the keypad manually by right clicking in Keypads (the old way)
Do the same for door station, right click and select Add Door station
This makes the number of keypads =2, and door station =1
write click on keypad or door station and select \"write modules to Comfort\"
After the write to Comfort the keypad #2 and door station 1will be able to work
What is the number of door stations in Modules and Settings
It should be 1 and you must do write to Comfort, after reset the door station wil be polled.
If the door station button still does not work, then either the Door station ID is not 1 or it is faulty
The doorstation was working fine before I swapped around the 2 comfort PCB\'s between my test and live systems. I only detached the blue connector plugs and have checked wiring and all looks ok.
The number of doorstations is zero and hence the warning on startup. Even if I hack the cclx and set to 1 (tried this) as soon as it scans it sets back to 0 again.
You dont have to hack the cclx file to add door station
After the scanning etc and before you write to comfort each time, On the door station tab, right click and select Add Door station, this adds a door station manually
