UCM/USB and Connection Instructions
The older version of UCM/USB is shown below. The difference is the new version has DIP switches ABCD instead of Shunts for SW7 Primary RS485 ID
Connect the UCM to Comfort using the 4 way RS485 cable below
DO NOT CONNECT the UCM Firmware programming cable shown below! This is only used for upgrading firmware
UCM Firmware programming cable. DO NOT CONNECT
The RS485 ID(SW7) determines the ID of the UCM. By default, the UCM ID is set to 1 ie ABCD are  all ON. Leave this at default ID
The UCM/USB is supported by Comfigurator 3.x.
Switch on Comfort with the UCM/USB and connect the USB cable to the computer.
When the UCM/USB is connected, a message \"New Hardware Found\" should appear, and the USB driver should be installed automatically.
If the appropriate driver cannot be found then a dialog to install the driver appears
Select \"Install from a list or specific location (Advanced)\" and then click \"Next\".
Select \"Search for the best driver in these locations\" and browse to  (\"C:/Program Files(x86)/Cytech/Comfigurator3/USB Drivers\") . Once the file path has been entered  in the box, click next to proceed. The driver should be installed and \"Hardware Ready for use\" is seen.
If the driver fails to install correctly, this may be due to an old version of the driver already in the PC.
See the forum topic http://www.comfortforums.com/view_topic.php?id=2431&forum_id=73 for instructions on how to fix this problem
Once the driver is installed,  go to Options > Settings >  UCM Interface. Select USB from the dropdown list
Click on the blue link \"Scan for USB Devices \" as shown above
Then click on the dropdown list to the right of Serial Number. You should be able to see a serial number in the dropdown list. If the dropdown list is blank,  unplug and reconnect the USB cable and repeat clicking on \"Scan for USB Devices\"
Do not check \"Via KT03\" unless the USB interface connected to KT03
If the serial number can be seen, press OK.
You are ready to connect to Comfort as explained below
Test the connection by selecting Transfer > System Information
If connected successfully, the window below wil be seen
If the connection settings are wrong, the message pop up will be
The the connection settings are correct but the login code is wrong, the message wil be
The USB01 daughterboard is shown. This can be plugged onto a UCM06 pcb (without any interface) to provide a USB Interface or to change the interface from Rs232 or Ethernet
Attached Image (viewed 109 times):
UCM06 UCM baseboard without any interface is shown below
[color=\"#ff0000\"]Check that the D9 (red) and D10 (Green) leds are both blinking on the UCM base board, Otherwise the UCM will not be able to log in[/color]
