01-10-2013, 12:32 PM
Greeting,
every once in a while the following problems with the KT03 Touchscreen Keypad (firmware 2.013) occur:
These problems seem to be related to the calibration of the KT03 device. We performed a touch screen calibration on the \"Setup/CALIBRATE\" page with a sharp object. The calibration went fine, judging by the feedback of the device (\"OK\").
These problems do not occur very often, but they do occur.
We are using Comfigurator 3.4.4.0
The bar code on the KT03 device is: C033113
- when entering the sign-in code on the \"Keypad\" page, after pressing a key on the keypad the key blinks black once, but the KT03 speaker does not beep.
- when entering the sign-in code on the \"Keypad\" page, after pressing a key once on the keypad the key blinks black twice and the KT03 speaker beeps twice.
- when entering the sign-in code on the \"Keypad\" page, after pressing a key on the keypad, the pressed key does not blink black, but rather a different key on the keypad followed by a KT03 speaker beep.
- on the \"Setup\" pre-page, after entering the sign-in code, the KT03 keypad does not enter the \"Setup\" page, although the signing-in was done properly (every pressed key beeped once). After that the user has to enter the sign-in code again until the KT03 keypad accepts it.
- on the main page, after pressing an icon, the KT03 keypad enters a different page, for instance, after pressing the \"Panic\" icon, the KT03 keypad enters the \"Zones\" page or the \"Control\" page, etc.
