Firmware V7
Will V6 firmware be upgrade-able to V7 by conventional means on all items of equipment?
V7 - Am I correct....... If we have a set up that is all V7 then the Comfort upgrade can be done by a \'simple\' pull down menu saying \'upgrade system\': presumably if you are on a PC with the relevant firmware or connection to the Ethernet then the whole process is done automatically !
Excellent
V6 can be upgraded to V7 with the current methods like programming cable, Upgrade by Bus or direct connection
With Comfigurator 3.6 and v 7 firmware you can select any module to upgrade and right click to upgrade any more, as shown in the screenshot in the original post
When are v7 firmware likely to start being released?
Being tested some will be released in weeks
