Threads: 19
Have a Comfort System utlising: Panel (8001/E); RGR03; KP02; KP03-WI; DP01.
I am intersted in adding the access functionality for arm/disarm for the system utilsing a rfid reader and keyfobs.
My question is, whether the UCM/ACCESS module is supported by the comfort 1. Also, the reader as advertised at Cytech.biz (Axeze) doesn\'t seem to be available in the UK. Has anyone managed to add this type of functionality to a comfort 1 system?
Any info appreciated?
Iain
Threads: 476
The UCM/Access may not be compatible to Comfort I
We do not sell the Axeze and Fingerprint reader in the UK anyway
Threads: 19
Thanks ident.
I had a look at the Axeze website and it seems that unit consists of a relay output \"to security systems\". If this is just a switch, and I have a spare zone, can I not just use another reader to zone x and configure this zone as disarm system?
Iain
Threads: 476
Yes almost all access control systems will have this type of relay output
You can connect it to a spare zone and program it as Switch Normally Open and use a Response to arm or disarm the system
Threads: 19
Ident. Many thanks for your help!
Iain
Threads: 868
Yes that should work, as it was designed to connect to alarm systems
1 second pulse is OK, zoone sensitvitity is normally 500 ms
It says
\"Smarthome does not offer technical support on this product, please contact the manufacturer directly for all product support.\"
Threads: 19
Thanks Slychiu. I have been in contact with Seco-Larm in regards suitability, but wanted to confirm with you guys first.
Appreciate all the help.
Iain
