Threads: 476
Have you tried this on another machine with the same OS?
Threads: 2
Unfortunatly I don\'t have another Server 2003 machine to test on but it\'s interesting to note that WizComfort works perfectly fine on this machine when pointed at the Comfigurator installation
Threads: 2
Right, installed comfigurator on another machine, freshly installed with server 2003 and.... it works.
Now i\'m stumped. I can\'t reinstall the main machine, because it\'s running so much stuff.
What options does that leave?
is there a debug mode for comfigurator I can use and email u the log output?
G S Kainth
Threads: 0
Has anyone managed to solve this problem. It seems that there are 2 other similar issues that have been posted on the forums. None of them have a response.
I have just installed tried to install comfigurator on a brand new vista machine (all service packs and patches applied) and have the same problem. I have also tried various versions of the software, but the all have the same problem.
I have tried running the app as administrator, set Windows 2000 compatibility mode. Nothing.
If no one has been able to solve the problem, could one of the Cytech folks comment under which circumstances the message is displayed. Maybe that can help us try to solve the problem.
Unlike the other postings, I can\'t put the software on a new machine, so I\'m stuck.
Please help.
Nic
Threads: 15
Hi Nic,
I cannot offer much help, but to say that it works fine on my Vista Basic acer laptop.
All versions including the new 2.2.0.
Sounds like you have some local curruption on your machine.
Regards Ian
Threads: 885
07-06-2007, 01:07 AM
(This post was last modified: 07-06-2007, 01:10 AM by slychiu.)
The problems posted regarding installation of Comfigurator on Windows Server 2000 was already replied and addressed in the post which has now been merged with this topic, see above dated April 19 2007
There are no issues in which there are no responses
In your case, can you be more specific as to what error messages you received when you tried to install the software in Vista. There have been several customers on Vista already who have no problem installing and running Comfigurator
regards
Threads: 0
Which version of Comfigurator are you attempting to run? The error you report suggests a problem with the licensing checking, but this has been removed in the latest version. If you\'re not using 2.2.0 then please do so. If the problem persists, please provide details of which version of Vista you\'re using - it runs with no problem here on Vista Ultimate.
Malcolm Green
Threads: 219
Just to add my note, I had no problem getting 2.2.0 or the previous 2.1.2 interim version of Comfigurator running on Vista Ultimate either. I am connecting via UCM/Ethernet so if there was an issue with licencing checks before 2.2.0 then I presumably didn\'t see it as the UCM/Ethernet licencing I understand circumvents this?
