Keypad green led not working, KP04
Hello, i\'ve a problem with a brand new keypad KP04.
The green led (security off) has newer worked.
The red ARM led works properly, but when i disarm, the green led stay OFF.
Reset doesn\'t work. Compete power off and restart, doesn\'t work.
ALL other 3 keypads works flawlessly.
I suspect a defective LED.
Is there some other things to search for, maybe in the keypad board itself (undocumented jumper, etc..)?
Thanks.
If you reset the keypad or cycle power all leds should momentarily turn on
If the green led does not, then it shows it is faulty
all the lights on the keypad is off only the home led light is flashing.
all the lights on the keypad are off only the home led light is flashing,also the telephone connect to the security system is given tamper alarm what can i do?
Home led flashing means there is a trouble alarm, most likely to be phone trouble based on your description. Check the phone line and if it is okay, try to sign in on the keypad to clear it.
no display on keypad and all the lights are not coming on only home light is blinking.
First, please do not post on more than 1 place. We will answer wherever it is
Which keypad model is this, KP01, KO03, KP04, KP05, KP06, KT03
What is the serial number and where did you buy it from and when?
Please answer in reply to this, and do not post a new message elsewhere
