08-27-2012, 01:56 PM
One of the things I feel is missing from my setup is a more intiutive user input device which connects to comfort. I understand touchscreens etc are available, but tbh, they are way out of my budget range, especially when considering you might want to deploy a few devices around the house.
I am specifically referring to wallmointed devices, like the scs, but more flexible, and able to provide specific feedback rather than just outputs.
One possiblity is to get some cheap android devices and see if they could be wallmounted and throw the adnroid app on to them, but if this is possible, perhaps it could be something cytech could consider producing ?
Some physical requirements for example:-
1) Wall mountable into standard backplates (same as scs)
2) Powered via 12v power
3) ethernet interface preferable, but wifi alternative ?
4) would run adroid app, but perhaps not need login codes for most functions.
A drawback with the current setup would be the limitation on number of connections to comfort at any time, and this may require some thought or limitations.
Regards,
Eamon
Regards,
Eamon
