Threads: 10
I have to upgrade my firmware to 6.
but if i upgrade the firmware i don\'t have the .bin file of the vocabulary that is currently installed and the central.
How can i upgrade the firmware to 6.0 (currently is 5.206 II SPC) withou loosing the vocabulary and have to change all the program again?
Threads: 885
Upgrading firmware should not affect the vocabulary, firmware upgrade and vocabulary upgrade are separate operations which have nothing to do wth each other
Threads: 10
ok... i\'ll tried now to proceed with the upgrade but i am not getting...
when i connect the programming cable and insert the jumper in PP2 like in the procedure url... when i turn on the central it get stuck and appear on the Keypad (ID#1 Ver.1.08r) and the keypad is biping constantly and i have no lights on the main board, the rio is blinking red, and the Ethernet is with normal lights.
The thernet is on ID2.
what can be the issue?
Threads: 10
01-31-2012, 07:53 AM
(This post was last modified: 01-31-2012, 07:54 AM by nbexiga.)
I dit not proceed because i got the error \"cannot connect to UCM\" one mote thinh is that while is beeping the red light in the RIO is flashing red....
only one thing that i did not do because i don\'t know what is.... \" SRN terminal block can be removed
Threads: 476
SRN terminal block is the siren connector. During upgrade the siren may be turned on so you can remove it
Just to clarify that the PP2 should be connected on the Comfort not the UCM
Can you turn on the Monitor I/O before trying again to do the upgrade
then save the monitor I/O and send to us
Threads: 10
yes the PP2 is shunted on the comfort.
when i connect the cable and the shunt and after turn on the central i\'ll put th I/O monitor on and see what i got , after that i\'ll update here with that info.
when i arrive home after the work i\'ll do that and post.
thanks
