01-21-2012, 03:00 AM
Version 2.009 - 25 April 2011
- Removed Warm Reset. All resets are cold resets now (ie. ID is read and all outputs are reset to off). No need to disconnect power when ID is changed, just press Reset button on RIO
- Supoort for Unknown command on RS485 Bus (21H)
- Resolved the problem that \"When shunt R at J2 is in open position, shorting any input won\'t make its corresponding output (connected to test bulb) to flash continuously\" as it should in normal operation.
