11-25-2011, 11:17 PM
In the next version update of Comfigurator - can we keep the response fixed eg the same number after we edit it if the Fixed check box is ticked before editing?
Stuart
Stuart
Request - Keep Responses Fixed after editing
Thanks Stuart
11-26-2011, 01:34 AM
Response numbers may have to change due to editing. Response slots take up 8 bytes. A response may take up several Response slots depending on its length
Hence if you add codes to a Response it may run over to the next Response slot which may be fixed so it has to find a new number where there are enough slots to fit in Hence when yoou edit a Response, it becomes unfixed. You will have to re-fix it after editing |
« Next Oldest | Next Newest »
