Away arming method - how to do more than one :-)
I remembered the other day I had forgotten to arm comfort when I left the house.
Tried to use iphone client to set it but it failed - realised it is as I have it set for final door - is there a way I can keep final door but have it use a timer if I arm from iphone or dial in?
Cheers
Stuart
I suggest you to use AutoArm command in a response.
Thanks for the hint max - does AutoArm bypass the usual exit route - then, cant play now as family home and wife would shout at me :-)
Yes, it does.It baypasses open zones and the final door terminator. Works very well.
Perfect - thanks so much!
