Response does not always seem to activate UCM Universal / RAKO
I seem to be having a few niggles with things - sometimes responces do what they should and sometimes they dont its always the ones involving RAKO -
I thought I was imagining things but I got home tonight and my outside spots were not turned on.
I have a responce call sunset - which gets activated at sunset Wink and that switched on my outside spots.
I thought thats wierd and manually activated the response - the lights didnt go on....
I then did it again like 2 seconds later and they did??
I happened to have the monitoring window open and this was the output....I cant see any difference?
This my sound silly but I dont suppose the RAKO unit goes to sleep or anything does it?
OK
> RS
< OK
> LI
< LU00
> LI****
< LU01
> UL000003
< DL00000305FF22D7
> V?
< V?FE060522200100
> v?
< v?05FF20010203FFFF
> U?
< U?0A060811
> LI
< LU00
> LI****
< LU01
> DA4A27FF
< RA00
> LI
< LU00
> LI****
< LU01
> DA4A27FF
< RA00
> LI
< LU00
Just had another funny - walking into the kitchen when the PIR detects movement it is supposed to switch scene 1 on.
Scene 1 activates 3 zones - what actually happened was that only one zone got switched on....
Its really wierd!!
I decided to manually run the response to switch the lights off and then back on from my pc when comfigurator threw up the message - the response in this configuraiton might not have been written to comfort etc...
When nothing has changed!!!??
ignoring the error then it wont switch the lights off.
ran it again and it has now switched the lights off - this is creepy!!! Glad Halloween is over!
Walked back into the kitchen - not changed any code at all and now scene 1 activated correctly with all 3 zones switched on....
Hi, schford, this problem seems relative to the response you created, I notice you use timer 0 in your response, sometimes time o is used by other parts of system,can you use other timer? if the problem still exist , can you send your latest cclx file to us so we can simulate your case and try to find the problem.
No it doesnt use Timer 0 in the kitchen responce it uses timer 5. Ill email the cclx..
Cheers
Stuart
AN update - home from work tonight and outside spots wer eon which is good - but kitchen is back to only switching on one zone instead of the 3 in scene 1!?
Stuart
Let us know if the solution sent by email by hefeng works
