Threads: 10
I have a long USB to my computer connected, during when I am trying to do PC->Comfort, I accedentally kick disconnected the USB cable hence lost the connection half way the transfer.
Now, I notice that my keypad has no sound and hang when press any key! I believe the vocab corrupted!
Even after reset system then i try to upgrade the vacab kate35 bin file, it say \"Vocab upgrade encounter errors\", \"The operation was cancelled\".
All the PIR are now all light on!
Please help urgent as I need to travel tomorrow! Now the system is not working.
I am on UTRAL5.214.
//ps
Threads: 888
Are you talking about kt03 or kp04?
You need to try vocabulary upgrade again
Even if there is vocab error the security system still works
You can arm and disarm even with no voice
I don\'t understand \"PIR lights on\"
Threads: 10
Hi Chiu
It is KP03.
I repeat many time vocab upgrade not working. After reset suppose to announce \"security off\", but no more.
Please ignore the PIR, it is working just no movement announcement due to keypad.
Pls advice.
//ps
Threads: 10
Hi Chiu
I uninstalled 3.2.8 and reintsall with 3.2.3 now.
Reset system, below is the monitor log of Vocab Upgrade:
> LI****
> UL000003
> V?
> v?
> U?
< LU01
< DL00000305FF22D7
< V?FE060522200100
< v?00000000000000000000000000000000
< U?0A05E411> VP0000BF18
> VL00002055BF165900BA02A00387048405D9072E08830A300BA60CE50E710FA5113113EFFE
< OK
< OK> VL002020176119C51C4D1ED521ED24AB27B129532AF52E0D3071332F35ED38513AD93CADD9
< VP0006
< NA
< NA> LI
< LU00
//ps
Threads: 888
Can you open Monitor I/O, log in and enter these commands manually
Just Copy and paste each of the 3 commands into the command window, let me know what is the result in Monitor I/O
VP0000BF18
Threads: 10
Hi Chiu
here is the reply:
> SR01
> VP0000BF18
< OK
< OK
< VP0006
//ps
Threads: 10
sorry, this is the reply of the 3:
> SR01
> VP0000BF18
< OK
< OK
< VP0006> SR01
< OK
< NA> SR01
< OK
< NA
Threads: 888
This message shows the the vocabulary failed to erase, not because of Comfigurator
Switch off Comfort power (and battery remove) for a minute, then turn on and try the upgrade again
If it still fails the Vocab flash may be damaged and may need to be repaired. However the alarm still works and you can arm and disarm only the voice and related functions do not work
