Threads: 14
Hi Chiu
Love what you are doing with the new firmware!!
Is it possible that the UCM05 / standard units Can be upgraded via the comfort bus as well as direct from PC?
I have a unit which is connected not to a PC, so It does mean have to play around with the wiring, which your new system does away with!!
Mike
Threads: 885
The UCM05 (I presume this is one with the RS232 Interface) can only be upgraded by direct connection toa PC. A module can only be upgraded by 1 method, direct or by Bus and cannot support both methods of upgrade
I think you should be able to bring a laptop to whereever the UCM is to do the upgrade
Threads: 14
thanks Chiu
I\'ve just read the other threads regarding this
sorry for the duplication
Mike
Threads: 55
Doqnloaded and upgraded firmware in 10 minutes.
No cable, no jumpers, no screwdriver.
Too simple now! Thanks.
Threads: 885
Thanks, we are glad you appreciate it
