Bus upgrade lists only one UCM, and refuses to upgrade
I have 3 UCM\'s which are viable candidates on the bus for an upgrade, all at v6.002 already.
Only one gets listed as a possible candidate for upgrade, and then when you do try, the final message is that \"Bus firmware upgrade not supported\"
And I did press F0
FYI - I have 2 x UCM\'s @ 6.002 and 1 x UCM @ 6.003
Only \"external\" UCMs can be upgraded by the \"Over the Bus\" method
UCM/ Eth UCM/232 and UCM/USB have to be upgraded by \"Direct to PC\" method
\'External\' ??
Not directly connetted to PC, means UCM/GSM, UCM/KNX, etc..
PC ---> (UCM/ETH, UCM/USB, UCM/RS232) ---> Comfort ---> (UCM/KNX, UCM/GSM, etc)
Hi !
We have a ucm/knx with firmware 6.015 that doesn\'t upgrade to version 6.112, despite comfigurator 3.6.5.0 say\'s it is available.
What was the error message?
Your Comfort firmware must also be version 6 or above
