Threads: 206
Excellent all moving in the right direction......
- would it be a good idea when signing in to somehow suggest that the * key is not needed and # keys should be used (well not when signing in but IS required ONCE signed in!) (perhaps use it for signing in as well - just to be consistent as it is required on the KP03/4 keypads!)
- Using a C1 board when arming - there is not count down visible on the iphone (as there is in red on the C2 board when arming)
- Using C1 board - i can sign in to main screen and arm BUT when i enter the code 1234# to disarm it tells me \"Code Entry wrong code entred\"!
- consistency of graphic design across all software - see other posts
Threads: 476
The * key is not required at all in the iPhone app
It could well be removed
The * key is used on a telephone or keypad if you do not want to disarm the system, but wish to access the voice menu As there is no voice on the iPhone keypad it does not matter if you press the * or not. The only reason for entering a code on the keypad is to disarm the security system
Comfort I is not compatible with the app. As it states, the minimum requirement is Comfort II 5.215 and UCM 6.002
Threads: 206
- the * key - its all about being consistent - you HAVE to have it for remote access using the telephone part of the phone so why not leave it in for ALL access instances THEN the customer will not get so confused.
- C1 not compatible I really do not think that this is a good idea! I realise that as a marketing tool you think that you will get more upgrades. weather this is or is not the case I am strongly of the opinion that you should make the app compatible with C1 systems. Perhaps offer the very basic arm and disarm pages and no more.
I think that you should do a pole on this subject - in terms of extra work - it already works apart from the bug i pointed out in the last e-mail, as a C1 app that is all you need no more.
By all means use it as a teaser but don\'t simply rule out all the 1000\'s of C1 users that have systems that work perfectly well and dont want to spend ã1000\'s upgrading in order to initiate a free app.
Threads: 206
- and the comment regarding consistency of graphic design across into other software!
Threads: 206
Of course everything takes time - appreciated BUT if you are not planning to have a consistent approach to the graphic design of ALL software from the onset then its not going to happen.
What i\'m talking about here is brand awareness peoples perception of the overall \'product\' not weather the app works or what it looks like on its own.
Get the app relaesed and then worry about the graphics will in my opinion not give you the best end result
Threads: 476
This is a bug in that page
If your cursor is in the PORT field, you cannot hit the RETURN button to get rid of the onscreen keyboard
Move the cursor to one of the IP address fields then hit Return. The value you have enteretd into the port field should remain there
