There has been much demand for an iPhone app for Comfort. We are happy to announce the first version of the official iPhone app. This is the first version, quite a simple one, and easy to set up and use. As with Comfort and Comfigurator, we will be improving it regularly.
Please note that this app is supplied for free by Cytech for the benefit and convenience of Comfort end users without any obligation. Please use it at your own risk. Cytech Technology is not responsible for any bugs, or problems caused by correct or incorrect use of the app.
The app can be downloaded from iTunes, look for \"Comfort Control\" or download from iTunes http://itunes.apple.com/us/app/cytech-co...98873?mt=8
This runs on iPhone, iPod Touch and iPad
Comfort System Requirements
Comfort II firmware 5.215
Download firmware upgrade from https://www.cytech.biz/comfort_ultra_fir...ory_id=101
UCM/Ethernet firmware 6.002
Download firmware upgrade from https://www.cytech.biz/ucm_firmware.html...ory_id=101
Functions Available
You must ensure that your iPhone is connected to the correct WiFi network ie the same as your Comfort UCM/Ethernet. If you connect to the wrong network you will not only fail to connect but will experience temporary lack of response from the App while it tries to connect to a system that is not there.
By connecting your Comfort system to a WiFi network you are potentially opening up a security vulnerability. Ensure that your Wifi network uses appropriate security.
The initial screen is shown
Press the KEY Icon to select the Comfort system that you wish to use. This brings
you to the Comfort Systems selection page.
Thie above screen shot shows two systems, but in the initial setup, it will be blank. Press the + symbol to add a system.
[color=\"#0000ff\"]The UCM/Ethernet can only accept 1 connection at a time. If another iphone or software eg Comfigurator is already connected, you will not be able to access.
[/color]
Tap the chosen system eg Office to highlight it and tap Done.
This returns to the home page showing the name of the Comfort system which was selected.
To delete one of the systems in the above selection page, simply slide your finger from the blue circle to the left
Enter the user code of your system and press SEND.
If the code is correct and the phone can connect to the IP Address and port, the connection icon will turn green
The keypad page is shown with the same LED indicators as in the keypad ie Security Off, Armed, AC and Message.
If the connection symbol remains gray, it means the user code is incorrect or the connection could not be made. Check the IP Address and try again.
Please note that the UCM/Ethernet accepts only one connection at a time.
There are 4 pages along the bottom; Keypad, Zones, Home Control and Alarm. Only the Keypad Page and Alarms Page have useful information at the moment because your iPhone does not know the Comfort configuration of Zones and Home Control.
The next section describe how to load the parameters from your cclx file into your phone
Functions Available
- Keypad Emulation
- Zone Status Display
- Home Control Menu
- Alarm events display
- Enter the Name of the system eg \"Home\", \"Office\"
- In WEB, enter the IP address and Port of the UCM/Ethernet on the Internet, if the system has a fixed or known IP address, and port forwarding has been set up, eg 201.203.110.117:1001. If not, leave this field blank.
- In LAN, enter the local IP address and Port of the UCM/Ethernet on the local network, eg 10.0.0.10:1001 This should be set up using the DS Manager Tool for the UCM/Ethernet which can be downloaded from https://www.cytech.biz/ds_manager.html
- Select USE LAN ON if you are connecting via the local LAN instead of the Internet (WEB)
- Tap DONE when finished to return to the Comfort Systems Selection page.
[/color]
