Threads: 62
04-14-2011, 03:24 PM
(This post was last modified: 04-14-2011, 03:33 PM by Ingo .)
What are the changes and fixes for the latest 5.228 UCM/Ethernet firmware? I can\'t recall seeing a new firmware release notification.
AND
I get the following error when upgrading from 3.2.7 to 3.2.8 and opening the application:
Exception while reading vocab.cfg:
System.Exception: Error reading C:\\Program Files (x86)\\Cytech\\Comfigurator 3\\Config\\vocab.cfg: Could not find file \'C:\\Program Files (x86)\\Cytech\\Comfigurator 3\\Config\\cs-wl-th.cfg\'.
at Comfort.Vocab.AddWordLists(Configuration configuration, String filename, List`1 wordlists)
at Comfort.Vocab.GetWordLists(Configuration configuration)
Ingo
Threads: 476
Not yet as that iis a pre-alert
Threads: 9
Is there a UCM update for the new Velbus modules?
Threads: 18
04-15-2011, 05:47 AM
(This post was last modified: 04-15-2011, 05:48 AM by gaynorc .)
I instaled 3.2.8 yesterday, being my first installation of Comfig 3 (up to now I stayed on 2). I have the same error every time I open Comfig 3.2.8:
System.Exception: Error reading C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\vocab.cfg: Could not find file \'C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\cs-wl-th.cfg\'.
What do I do?
Threads: 476
You seem to have a missing file. Can you copy the attached file to the Comfigurator\\Config folder and try again
cs-wl-th.cfg (Size: 6.76 KB / Downloads: 4)
Threads: 18
Okay thanks that seems to have removed the error.
Threads: 9
When doing a learn request i see activity on the velbus network after about 30 seconds a message \"No responce to Velbus Learn Request\" pops up.
After clicking ok it continues to reed the UCM/Velbus EEPROM when finished any new module or address change shows correctly in the Velbus to Comfort window.
Comfigurator 3.2.8
Comfort 5.211
UCM/Velbus 5.228
Thumbnail(s)
