Blinds relay
Any chance of a blinds relay unit similar to the CBUS blinds and shutter relay (but on the Comfort bus)
- safety interlock
- reverse polartiy and split winding motors
- mains and low voltage
- LED indicator up down
Thats also a good suggestion
Do we have any progress on this topic - is it on the agenda yet?
Afraid we are not so fast
I don\'t suppose.......
That will be in the \"Intelligent\" RIO
Not my preference
If you have mains blinds then I would not want to bring the 240V blinds feeds into a main comfort enclosure.
Take another look at the CBUS blinds relay - it is well though out and accomodates both reverse polarity (usually 24Vdc) motors and split winding (usually mains) motors.
ALSO the CBUS unit has manual over ride - very important.
Tacking it onto the back end of a RIO is not what we are after.
Is it such a silly suggestion
It will only need the KA/KB
All powered locally
It could control the blinds and give some cheap remote inputs to boot
I\'m sure by now it could be fitted into a small smart box
Mike
Its not s silly suggestion at all and can readily be achieved.
Here are the down sides once again
- What ever is said the RIO option will encourage the use of mains power in the same enclosure as the main CPU or UCM\'s
- In our design we always try to offer \'manual overrides.
The CBUS blinds relay is well though out and inexpensive.
RIO need not be in the same enclosure as Comfort, it can be separate
I dont se what is the problem with manual override
Cbus is not suitable for all installations. It is not cost effective to add just a Cbus blinds relay to a non cbus system
