Threads: 189
I am aware that there is a facility to print out the Comfigurator settings but this amounts to 10\'s of pages.
Could we have the following facility
- Print out a summary to include: Presentable text/graphics to give to customer: installer details: A4 printout
- Service record / history: enhance the comments box to include a file version history with notes: a spread sheet with the zones visible so that the service records can be kept with the file over the history of the install.
I think that this would go a long way to pushing installers/customers into good house keeping - the number of properties that we have taken on over the years with no documentation what so ever........
Threads: 476
Good suggestion.
You suggest that only some of the information currently printed is neccesary then?
and the printout is only for the customer?
Threads: 189
I think that as you already have the complete printout it may be advisable to keep as you can always print selected pages.. (If I recall the page print number did not tie up with the actual page number on the document)...so
- Full print out (similar to exisiting) basic fonts nothing glossy functional full report. - perhaps an export / save to pdf or similar
- Print out a summary to include: Presentable text/graphics to give to customer: installer details: A4 printout: perhaps an export / save to pdf or similar
- Service record / history: enhance the comments box to include a file version history with notes: a spread sheet with the zones visible so that the service records can be kept with the file over the history of the install: perhaps an export / save to pdf or similar
Hope this helps............
Threads: 189
With the imminent release of 3.2.5 can we have this feature enabled please?
Threads: 189
Any movement on this yet?
Threads: 189
Do you have some sort of rating for actioning these suggestions.. Perhaps a 1 - 10 may be an idea 1 being imminent 10 being not likely.
Threads: 105
10-29-2011, 11:56 AM
(This post was last modified: 10-29-2011, 11:58 AM by ndh.)
I\'ve not read all this in detail but it would be good to be able to print to txt or word file etc. Then it can be edited as required.
Now that Comfort is getting more and more sophisticated \'remming\' in complex responses is getting more and more important. It would be good if there was an option for individual response descriptions to carry over when they are called \'Do Response\'.
This then apears in the documentation.
e.g.
RESPONSE DESCRIPTION
Output1On Turns output 1 on
A Response:
If ....
Do Output1On Turns output 1 on
EndIf
I\'ll repost this if elsewhere if somewhere better.
Nigel
Threads: 189
Can we make a point of adding some of these more \'minor\' but very valid points into the next release please..
