I can\'t seem to get my 2 KP04 keypads to produce voice/speech sounds any more. They stopped working after I changed the install layout. I have updated the boards firmware, the UCM/Ethernet\'s firmware and tried installing the Kate29.bin vocabulary. The usual Transfer - Vocab upgrade failed with communications errors every time after 6-12% so I completed it using the Transfer - Sentence tables upgrade which worked.
The *+1 combination to download to the keypads took MANY MANY attempts to get it to complete, most times it would go a few blocks and freeze.
I have reverted to the default Comfort Ultra II set-up in Comfigurator V 3.1.8.0 and still no luck. (Config file attached). I have removed 1 keypad from the system and left the ID#1 on to rule out issues with the other one.
System details:
Comfort II Ultra Version: 5.183
File system: 34
Vocabulary No.: 5
Custom vocabulary: No
System vocabulary No.: 29
User vocabulary version: 1
LCD text version: 1
LCD maximum version: 3
UCM type: 10
UCM Version: 5.192
KP04 version: 1.012
I\'ve confirmed the cabling is correct, and the LCD display and buttons work as they should but not the voice sounds. The internal speakers are working I think as the keypad makes a sort of faint static where there should be speech, so it\'s trying to say something and the siren works from the keypad on alarm.
Is the KP04 version = 1.012 an issue as I read in the manual something about requiring version 1.3+ ?
Paul
Edit: This is the bit in the KP04 manual that has me confused about what version the KP has to be. What are they asking me to do in points 2 & 3 to get sub 1.03 KP04\'s to work??
1. Power up the KP04 by connecting ONLY the 12V/COM. The KP04should display the version number as the time on the LCD screen.For example, the version shown in the image below is 1.01.
2. If the version shown is 1.01, then download the correct default found on https://www.cytech.biz/software.html.
3. Following that, download the configuration into the keypads using the LCD Keypad Language Customisation Software
4. If the version shown is 1.03 or later, connect up the KP04 to Comfort as per normal.5.Should there be a mismatch between the versions of the language displayed and the vocabulary on board Comfort, the KP04 will displayââ¬ÅWrong Text. Press *1 to syncââ¬Â.
System details:
File system: 34
Vocabulary No.: 5
LCD text version: 1
UCM type: 10
UCM Version: 5.192
KP04 version: 1.012
Paul
