Extending the distance of UCM/GSM from Comfort
The new ADM02 (Auxlillary Distribution Module) pictured below has additonal terminal blocks for 12V/COM, KA/KB and MIic/Voice and 4 way connectors (KA/KB/12V/COM) to supplement the terminal blocks on Comfort
In addition, it also allows the UCM/GSM module to be located remotely from Comfort.
There is a 5 way GSM connector on the new ADM02. This plugs into the J54 GSM connector on Comfort.
Use the terminal blocks for GSM Audio (SP+, SP-, MIC+, MIC-) to connect a shielded CAT 5 cable to the same pins   on another ADM02 Module (SP+, SP-, MIC+, MIC-) which is then connected to the UCM/GSM which can be far away
Hence you need 2 ADM02
For remote installation two 5-way cables are required then per above. Will you ship ADM02 with add\'l 5-way cable as only one comes with GSM module?
regards, rolan
yes, GSM cable is included with ADM02
