05-07-2008, 09:18 AM
I have just upgraded to firmware 5.121 and noticed different behaviour in the keypads. I\'m not entirely sure that the keypads didn\'t exibit this behaviour previously but I don\'t recall noticing it before. The behaviour doesn\'t appear to cause any problem but it wasn\'t in the change notes so i\'m not sure if it should be expect.
The keypad\'s green \'off\' led remains lit only for a short while after system reset and then switches off. Signing in at the keypad turns it back on but then it switches off again.
Also, the keypads usually show zone/pir activation but one of them turns this off along with the green \'off\' led. Is there a way to change this?
Thanks,
Tas
Thanks,
Tas
