LEM01 pcb - fitting on top of master CPU or slave pcb - Printable Version
+--- Forum: Expansion Modules (https://www.comfortforums.com/forum-91.html)
+--- Thread: LEM01 pcb - fitting on top of master CPU or slave pcb (/thread-5877.html)
LEM01 pcb - fitting on top of master CPU or slave pcb - Home - 06-11-2026
I am about to fit a new SEP with outputs (OP01) and include an LEM01 with outputs.
Firstly if I try to fit the LEM01 on op of the master slave then there are NOT 4 fixing holes (i can only match 2 on one side).
Secondly if I fit the OP01 pcb to the base SEP pcb then there is no space at all for the LEM01.
Would it not be best to supply the LEM01 with a longer ribbon cable and say it does not fit on top of the master or slave !
