KT03 Time & Date Alignment in Portrait Mode - Printable Version
+---- Forum: Keypad (https://www.comfortforums.com/forum-69.html)
+---- Thread: KT03 Time & Date Alignment in Portrait Mode (/thread-3015.html)
- MJC Electronics - 08-16-2012
I\'ve just installed a KT03 in portrait mode and have used the configuration file from the standard Comfigurator install as a base for downloading a program to the KT03.
On the home page, that time and date are out of alignment with what is shown in Comfigurator. They come up on top of the status indicators at the bottom of the screen.
It seems that the vertical location values are somehow inverted because if I move the date and time fields to the bottom in the program and then transfer it to the keypad they appear at the top.
- ident - 08-16-2012
We have also found this bug in portrait mode and we wil have a new version shortly to fix it, currently being tested
Thanks :dude:
- ident - 08-17-2012
The new KT03 firmware 2.013 has been released which fixes this problem see http://www.comfortforums.com/forum104/3019.html
