- ident - 12-22-2011
Bug Fixed- Fixed BUG when announce event log on phone, all KPs displayed event log as well
- Fixed BUG from 6.006 cbus and KNX arm buttons cannot work.
Improvements- Start Watchdog earlier after reset so a disturbance due to a lightning surge is less likely to cause the system to hang with RED and Green Leds. Enabled watchdog before testing of U4 EEPROM and DSP so as to allow watchdog to work if system hang after lightning. Suspect when system hangs, and red and green leds are on, the eeprom test failed due to surge and dsp test also failed so watchdog did not work.
- After reset RED and GREEN leds will be off . The RED led turns on before testing U4 EEPROM
- When there is an alarm and the keypad is used to disarm, alarm history will not be heard automatically, as this may confuse users, menu will say \"Security Off\" and exit from menu
- Initial date/time changed date to 07 December 2011
- Set alarmstate=0 (Idle) before Security Off Misc Events Response so the response can re-arm if an Entry delay is active
- Maximum Do Action Rs485 commands increased from 48 to 64 eg DA commands
- RS485 receive buffer size increased from 127 to 240
- User Numbers in Event Log and UCM messages
- Changed user number assignments - Engineer Code from 18 to 254, Keypad arm from 90 to 240, Auto arm (Response) from 91 to 241, CMS from 94 to 244, SMS from 95 to 245, UCM Ids 17 to 24. When cbus or KNX UCM etc arm system without code, the event log will record UCM ID 17 to 24. Key arm by action 72 is recorded at User Key Arm, Action 71 Auto arm is recorded as User Response.
- For Event Log there is incompatibility between events recorded by old firmware due to user number changes. Before upgrade, read event log and save
- Key arm using KD message reports UCM ID as user number instead of User 240, but Key Arm by keypad will still report key arm user 240
Changes for GSM/SMS - Changed SMS Text message. Arm by Cbus , KNX etc without code reports User UCM ID number instead of User Keypad eg XXXX-AA-18 UCM #2 if armed by UCM#2 KNX. Before, Arm by KNX is shown as XXXX-AA-90 Keypad so it appears wrongly like armed by keypad.
- SMS Format change to 3 digits for User, ID or Zone Number
- GSM SMS Text message sends Alarm Type Number before alarm name and Zone/ID/User Number before its name so ucm/cms dialer can work FIXED BUG from 5.225
- When armed by ucm eg Cbus or KNX, ID is ucm id instead of user 90 for keypad so arm by ucm is identified in event log and UCM protocol
- SMS Alarm \"User RESP\" change to \"User Response\". If user number arm/disarm, NN User# change to NNN User. And User#KP to User KP ie removed #
New Features
- Supports 96 Inputs and Outputs. Slaves which are on ID 4 and 5 require SEM firmware 6.007. Comfigurator 3.4.3 is needed. KP04 firmware minimum is 1.018
Known Issues- Assigning Output to Security > Status LED will cause KP Home/Armed LED to show the wrong status (from 5.220)
- [color=\"#5500ff\"]Engineer User number 254 is not supported by Comfigurator version up to 3.4.3, so if \"Require Engineer Code to write to Comfort\" is checked in Modules and Settings, the engineer code is not accepted. To work-around, uncheck the \"Require Engineer code\" option before upgrading to 6.011, then do write to Comfort. This ensures that a user code can be used to write to comfort[/color]
- [color=\"#5500ff\"]Transfer > Sentences Tables Upgrade does not work unless Vocab Upgrade has been done earlier. It causes the voice to be lost temporarily[/color]
- [color=\"#5500ff\"]Scheduled Reminder Messages do not work at the correct time (from 5.173)
[/color]
Note that known issues are not necessarily new to this version
Please download firmware file from https://www.cytech.biz/comfort_ultra_firmware.html
Note that products may not come with the latest firmware when bought from distributors. Please check the website or forum for the latest firmware and upgrades
- ident - 01-10-2012
The change of Engineer User number from 18 to 254 is not supported by Comfigurator version up to 3.4.3, so if \"Require Engineer Code to write to Comfort\" is checked in Modules and Settings, the engineer code is not accepted. To work-around, uncheck the Require Engineer code option
- Stub - 01-15-2012
My installer and I upgraded my Comfort Ultra ][ firmware to 6.011 the other day. We also updated my Ethernet UCM firmware and Comfigurator to 3.4.3.
I was previously using a late series Comfigurator 2 which required an Engineer code to update Comfort. I think I was on a v5 firmware but I can\'t be sure on that.
Anyway, after the firmware upgrade we were unable to update Comfort from Comfigurator because it wouldn\'t accept the Engineer code. We tried unchecking the Require Engineer code option, as suggested here, several times without any success.
Unsure what to do about this problem my installer had the thought to delete user mailboxes via the keypad. This reset things sufficiently that we could use the default engineer code of 6789 I think it was. We were then in a position to return things to normal by uploading a new configuration to Comfort.
We had a look in the raw comfigurator files for the Authorisations section and we still had the engineer code on 18 rather than 254 as suggested here. This was in both my updated comfigurator file and in a default file we saved while attempting to restore access.
- ident - 01-15-2012
Yes, the \"Known issues\" list states that Comfigurator 3.4.3 still looks for Engineer Code Number 18 instead of 254
Once you are able to write to Comfort, you can uncheck the \"Require Engineer Code\" Box. After the write, you should be able to use a User code instead of engineer code.
If you still have problems, downgrade to 6.006 and then uncheck \"Require Engineer Code\" before writing to Comfort
Added note in Known Issues to Uncheck \"Require EngineeR code to Write to Comfort\" and do a Write to Comfort before upgrading to 6.011
The older firmware 6.006 is attached just in case
- ident - 01-31-2012
New bug found in Comfort fiirmware
