Protocol Question - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Protocol Question (/thread-2461.html) |
- juwi_uk - 09-10-2011 Hi Can you expand on the following new command extensions in the protocol manual. The revision history says they are \"defined\"; are they available in a released firmware yet? If so, can you also use these via a few example sequences. Regards Julian ----- 12 June 2011 E? extensions E?NNNN format is iimplemented where NNNN is an event index NNNN = 0000 means 1st event. 00 is also accepted as 1st event for compatibility NNNN = FFFF means last event NNNN = FFFE means previous event NNNN = FFFD means previous day last event NNNN = FFFC means next day 1st event - ident - 09-11-2011 These still have not been implemented yet in any firmware yet These commands are mean to allow navigation through the event log like what is possible in the voice menu event log function is F5 |
