keypad communication failure - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Keypad (https://www.comfortforums.com/forum-69.html) +---- Thread: keypad communication failure (/thread-2207.html) |
- m.khairy - 03-28-2011 i have a kp04 , when i communicate it with the system the message that appear on keypad is keypad communication failure and the system doesn\'t work i tested the cable , it\'s good and isolate all i/o however the problem is still - ident - 03-28-2011 This message means the keypad is not communicating with Comfort either because the KA/KB wires are connected or the ID on the keypad is not set correct If there is only 1 keypad then the ID should be 1 ie the shunts A B C should be connected The Number of Keypads in Comfigurator should match the number of keypads in he system and each ID should be set unique - m.khairy - 03-29-2011 Thanks for replying But, The KA/KP wires are connected i have only 1 keypad and the ID is 1 The number of keypads in comfigurator is 1 The problem is still - hendy - 03-30-2011 How long is the cable connecting the KP04 to the Comfort panel? Try connecting them with a short cable e.g. around 1 meter and see if it makes any difference? Could it be that the KA/KB connection is reversed i.e. KA goes to KB and vice versa? You have mentioned the keypad ID is 1 so all shunts A, B, C, D have been ensured to be closed or shunted? And one more thing, when the Communication Failure displayed on the KP04, what Keypad number is displayed? Is it Keypad 1 e.g. \"Communication Failure Keypad 1\" or some other numbers? - m.khairy - 03-30-2011 Communication Failure Keypad 1 - hendy - 03-31-2011 Have you tried with a short cable? - ident - 03-31-2011 what else is connected to KA KB? are these other modules working? Can you connect a UCM to Comfort and communicate? What are the state of the red and green leds on Comfort PCB - m.khairy - 04-06-2011 The problem was in the firmware update , when i updated the firmware the keypad worked correctly - ident - 04-06-2011 I think there may have been a firmware upgrade attempted before which was not successful which caused the system to be inoperative. |
