Comfort Not detecting Ring - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Dialing out and Auto-Answering (https://www.comfortforums.com/forum-70.html) +---- Thread: Comfort Not detecting Ring (/thread-1572.html) |
- Warby - 08-17-2009 I have just replaced a ULTII main board with a new board as we have been having problems with comfort not releasing the line after dialling out. Now on the new board it doesn\'t detect a call coming in. I cannot hear the relays clicking. i have tried reversing tel in and there is 50v dc and 70v ac when ringing. pressing # on the local phones works but only when the tel in is a certain way around. i have tried setting answer machine bypass on but it still doesnt work. It is currently on FW 5.164 and i have tried 5.169. using Comfigurator 3.1.1. The leds on the main board are okay. Please Help!!! - admin - 08-17-2009 Can you try disconnecting the TEL OUT connector so that telephones are not in the circuit? This tests if the connected phones have any effect. - Warby - 08-17-2009 Makes no difference. I have put the old board back in and it works. though we may still have the issues if comfort not hanging up after dialling out. So faulty board? |
