answer problem - Printable Version
+---- Forum: Dialing out and Auto-Answering (https://www.comfortforums.com/forum-70.html)
+---- Thread: answer problem (/thread-1333.html)
- ruirego - 02-02-2009
If the comfort is programmed to answer at 1 or 2 rings, everything is ok.
When I change it to 3 or more rings it doesn’t answer???
Any idea Thanks,
Rui
- tech07 - 02-03-2009
What firmware are you using? You should upgrade to 5.145 This has a change which should fix the answering problem for Portugal where the first ring has a very long silence, see http://www.comfortforums.com/forum60/1195.html
