Comfort picks up phone line after ring - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Dialing out and Auto-Answering (https://www.comfortforums.com/forum-70.html) +---- Thread: Comfort picks up phone line after ring (/thread-797.html) |
- palmlodge - 11-29-2007 Bump - Bump ! - admin - 11-29-2007 Quote:I am afraid we cannot make progress on this unless we can duplicate this and see for ourseves. Is there anyone in the UK or elsewhere who has encountered this problemI am afraid we dont have a solution for what I see as an unknown signal on the telephone line which causes Comfort to answer the call when the number of rings is sset to 0 or 1. We have not found such a problem in our own testing. - palmlodge - 11-30-2007 Understood. I can happily reproduce this so thats not a problem. I just need you to get this fixed ! What do you need from me to resolve this ? - admin - 12-01-2007 We ned to put on our thinking caps on this but give us time - palmlodge - 12-05-2007 I reported this 15 months ago :-) Lets hit it hard after christmas. We can do some serious testing work then. - admin - 12-06-2007 I have to say that we cannot guarantee that we can make any progress on such a condition. Comfort may not be able to do everything that all users expect, no matter how much we try. regards - palmlodge - 12-12-2007 This may also be related to the fact Comfort saves Answerphone messages for someone who has already hung up - and Comfort then opens the line itself after hang up. - palmlodge - 12-19-2007 Done some more testing - using the On Hook and Off Hook responses. When these responses are triggered, they set a counter. If I pick up the phone line, the counter gets set, and it\'s logged in homeseer. If you call the house, and pick up the phone, the hook responses work. So, last night, at 10.42pm, Comfort has recorded the BT message \"please hang up and try again\" - you get this if you pick up the phone and dont dial a number. Calling 1471 shows no one called at that time HomeSeer shows no \"Phone Ring\" activity at that time (as reported from Comfort) The on/of hook counters never changed. So, Comfort is picking up the line, but none of the usual triggers from Comfort show this has happened. You have stated there\'s something on my line causing this - but even if that were true, all of the above triggers in the logs would show some activity. This is a definitely a Bug. - palmlodge - 12-20-2007 Again at 2.47am this morning On/Off Hook nor Ring Detect flags triggered. 1471 shows no one called the number. - palmlodge - 12-21-2007 Again at 4.50am this morning |
