UCM 7.054, 7.056 (beta) - Printable Version
+---- Forum: UCM Firmware (https://www.comfortforums.com/forum-81.html)
+---- Thread: UCM 7.054, 7.056 (beta) (/thread-3937.html)
Pages: 1 2 3
- juwi_uk - 08-29-2014
Whilst it wont help the scenario this time around,  could you make use of the U3 eeprom in the future and change the  upgrade process so it saves a copy to there somehow and use this like a, what would be in PC terms, crash-free bios and be able to recover from in these type scenarios.
Maybe just save the previous firmware to there before it upgrades and any issues if can be reverted back somehow?
- ident - 08-29-2014
Saving firmware to eeprom will not help if the firmware is corrupted, as you need  working firmware to read the eeprom
For UCM 7.054, once you try to self upgrade, the firmware is corrupted
Save the previous version to the U3 chip before the new upgrade download starts.   If it fails for any reason then restore from the U3 chip previous version.
Maybe the firmware upgrade cant always do the auto recovery as it doesn\'t necessarily know it is broke; this actual use case in this thread is a good example of that.
But to recover then you could have some ring-fenced code that could recover from U3.  then to initiate the restore retrospectively you just set a Boolean at a memory address X and reset the system and it auto recovers.
That\'s my suggestion anyway.
- tman - 08-29-2014
Quote:Save the previous version to the U3 chip before the new upgrade download starts.   If it fails for any reason then restore from the U3 chip previous version.
The EEPROM fitted is only 32KB.
Yes, there is also that little problem
The UCM/GSM4 baseboard has a 256K eeprom (24LC256) in U2 for a start so 32K cannot be the max even if you have in your specific UCM
That said I\'ve no idea what it would need to be anyway.
J
- tman - 08-30-2014
Quote:The UCM/GSM4 baseboard has a 256K eeprom (24LC256) in U2 for a start so 32K cannot be the max even if you have in your specific UCM
J
24LC256 is a 256Kbit EEPROM which is 32KB. The UCM firmware file is 256KB.
- ident - 08-30-2014
UCM 7.056 (beta) fixes the bug in 7.054 (corrupted by self upgrade)
Bugs Fixed
  1. UCM 7.054 cannot be upgraded except  by another UCM
New Features
  1. Implement new UCM command r?TTxxNN query sequential registers where TT = type 0 for Counter, 1 for sensor, xx= starting register no, NN is no of registers. Reply from UCM is r?TTxxNNaaaabbbbccccdddd...... Requires Comfort firmware 7.062
  2. Allows all RS485 modules to be upgraded if the firmware is version 6 including future KP04
- juwi_uk - 08-30-2014
So where does that leave users on 7.054 with just the one UCM as was asked by one user?
we are still considering the best solution. If there is anyone else who has upgraded to UCM 7.054 please send email to support@cytech.biz or send a PM
