Comfigurator 3.7.6 exceptions - Printable Version
+---- Thread: Comfigurator 3.7.6 exceptions (/thread-3545.html)
Pages: 1 2 3
- gaynorc - 11-04-2013
My file sent as requested.
- ident - 11-05-2013
Thanks for the file, we have duplicated your error and will have a fix in the next maintenance version
- sbrown - 11-11-2013
Same problems here - can\'t run 3.7.6 at all. On opening I get the XML error in def34.cctx and if I open one of my own config files I get the same Unhandled exception as above.
This means it\'s surely a application error rather than a config file error. Could really do with an update to correct this as it\'s completely unusable at the moment and needs a restart or forced quit just to try to close comfigurator down once the unhanded exception error hits.
This is running on XP in Parallels. Now having to re-download 3.6.8 as it\'s currently unusable at all.
- ident - 11-11-2013
Is this the same exception as the previous ones shown by gaynorc and palmlodge?
Those exceptions occur when trying to close the program following an Undo
We are not aware of an exception when opening the file, except for the ones caused by errors in the  .NET framework as shown in the 1st 3 posts of this topic
Please send the screenshot of the exception for verification
- ident - 11-14-2013
We are trying to clear up the bugs and exceptions found in 3.7.6 and release a new version, b ut we are still waiting for more information about the exceptions found when opening Comfigurator as we have not experienced it and are not able to duplicate
Those who have this problem please send screenshot and exact sequence to trigger if possible
- ident - 11-23-2013
For those who encounter exceptions with 3.7.6 please upgrade to 3.7.7 beta  and let us know if that fixes your exception problem
http://www.comfortforums.com/forum20/3619.html
- ident - 12-03-2013
So we conclude the the exceptions in 3.7.6 are no longer seen in 3.7.7?
- gaynorc - 12-03-2013
On the error which I reported in 3.7.6, I have tested doing an exit from comfigurator AFTER I have performed an \"edit -> undo\" on a change I made, and I do not get the exception with 3.7.7.
- ident - 12-04-2013
Thanks for the confirmation
- mikegriff - 12-12-2013
I get this whenever i try and print
It has been there since 3.7.6 now on 3.7.8
I\'m running windows 7 fully upgraded
Mike
