Comfort iPhone App v 1.3 Comments - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +---- Forum: Comfort iPhone App (1st generation) (https://www.comfortforums.com/forum-96.html) +---- Thread: Comfort iPhone App v 1.3 Comments (/thread-2282.html) Pages:
1
- slychiu - 06-29-2011 In other words, do not open the email using webmail application in Safari. That willl not allow you to use the attachment. Open the email using the Email application built in on the iPod or iPhone - HomeIQ - 07-07-2011 [user=318]wexfordman[/user] wrote: Quote:Just another thought also, would it be possible in the next rev to display inputs and status etc in different colours dep on status? Makes it easier to see! What about an option to only show active zones only?...it makes it much easier to monitor on small screens - slychiu - 07-07-2011 Good idea, but I think it would not be appealing when a zone opens to suddenly appear and push other zones down the list - ident - 07-30-2011 Replies to wexfordmans questions which we have just noticed Remember that when you EDIT a post there is no email notification to those who are following or watching the forum so your edited post may not be noticed except when you actuallly see the post. If you Reply then an email will be sent to those who are watching the forum [color=\"#ff0000\"] I wonder would it be possible however to keep the app running in the background but limited to reporting certain events or status ? No option to ent[/color] It is not desirable to have the app running in the background because that would ties up the connection and others who wish to connect would not be able to do so, as the UCM/Ethernet is designed to accept only 1 connection at a time for security reasons [color=\"#ff0000\"]when you activate a response (ie push the blue arrow), there is no confirmation/acknowledgement that the action was entered even within the app. I sometimes press the blue arrow a few times to ensure that I have actually clicked it before returning to view the status. If the app did something like \"ok\" to give confidence that you had pushed the button this woudl add confidence. That and as you mentioned, showing status on the same page as the control [/color]In version 1.4 of the app tapping on the blue arrow buttons gives a audible feedback so you know that the key is pressed [color=\"#ff0000\"]One other consideration/comment. With the app, in my case for example installed on two iphones, and if and when an android app comes out, it\'s be going on a third, in addition to the cwm, how will the number of connections to comfort at any one time be managed ? FOr example, two apps cannot log in at the same time I beleive ?[/color] The UCM/Ethernet will only accept one connection at a time. in Version 1.4, the connection status is shown in the keypad/login page so you will know whether you can login before you try to do so |
