Posts: | 5758 |
UCM/GSM4 v7.106 beta firmware has the following changes from 7.100;
- The Status value in the bottom left of the UCM/GSM screen will show the current GSM signal strength 0 to 4. In previous firmware, the GSM signal strength is displayed only for 1 second after which is followed by Normal/No Error. The status "Normal/No Error" has been removed as it provides no information and prevents the GSM signal strength from being displayed.
- The signal strength 0 to 4 is followed by text describing the level number, eg 0 - No Network, 1 - Weak, 2 - Fair, 3- Good, 4 - Strong. This is not done by firmware, it is in Comfigurair defaults. To update the defaults, go to file > Update Defaults in Comfigurator. This updates the defaults. Close and restart comfigurator to activate the new defaults
