GSM4 v 7.035
 Rating:  Rating
 Posted: Thursday Jan 16th, 2014 05:38 am
Known Bugs
  1. Phone numbers with 7 digits will get the wrong reply when sending SMS to the UCM/GSM4. The UCM/GSM4 will always send the Help Text (1) and (4). This occurs if 7 digits appear in caller ID. Note that this may or may not include the country code, depending on the carrier.  This problem has been reported in South Africa and Cyprus. Please upgrade to GSM 7.048
This new firmware 7.035 fixes a problem that affects some gsm modules (rarely)
Only a few users have reported this  issue.
The module is unable to reply to SMS messages from a programmed phone. However it is able to send SMS to the programmed phones in the event of alarms
 Posted: Thursday Jan 16th, 2014 06:57 am
Can you clarify "some gsm modules" point; do you mean modules of the different chipset types that have been Introduced over the last few years or within certain modules  of the same chipset type.
My question is because this is posted at a gsm4 firmware but surely this is SIM900 chipset only? Are you saying there are different batches of these?
 Posted: Thursday Jan 16th, 2014 07:02 am
Yes this affects SIM900 only
It is not related to a batch of product. More of the conditions of the network, eg if the network is poor
It should not affect older UCM/GSMs
 Posted: Sunday May 4th, 2014 01:49 am
hinis
I have the following issue with UCM/GSM4 (7.035)
Whenever I send an SMS command to comfort the reply is the help menu main screen i.e.
(1) - Help for arm security
(2) - Help for control
It does not accept my command for arming (11) disarming (10) or (1) (4). It always replies as above. My number is authorised for SMS arming, disarming and control.
 Posted: Sunday May 4th, 2014 07:28 am
Is your Comfort upgraded to the latest version ie 7.046 or above
If so send your cclx file to support@cytech.biz
 Current time is 03:24 pm
