UCM/Velbus 7.006
 Posted: Thursday Jan 24th, 2013 04:27 am
Known Bugs
  1. If Send Date and Time to Velbus is checked and VMB4PD or VMB1TC is in the Velbus to Comfort tab then the UCM/Velbus will reset every 5 seconds
Changes
  1. UCM/Velbus ID can be changed by using COPY Button Press and Hold. The LEDs show the binary ID codes when Copy button is pressed. ID can be changed using Comfigurator 3.6 drag and drop
  2. UCM/Velbus Module Status is  displayed on the status bar which is very useful for testing and troubleshooting. The possible status information includes;  "Normal/No error" “EEPROM missing/faulty" "EEPROM insufficient capacity” "EEPROM data invalid" "Communication error between UCM baseboard and sub-module"
  3. New Velbus Modules are supported
  4. Write and Read from EEPROM is faster
Comfigurator 3.6.4 is required to support the new features, see forum at http://www.comfortforums.com/view_topic.php?id=3261&forum_id=20
Comfort firmware Version 7 and UCM/USB or ETH02 firmware version 7 are also required. Firmware can be upgraded using Comfiguratoro 3.6.4 in Modules Tab, riught click on module and select "Check for Updates"
The revised UCM/Velbus Manual can be downloaded from http://www.cytech.biz/ucmvelbus_manual.html?category_id=107
 Posted: Tuesday Nov 26th, 2013 12:26 pm
Please note a bug just confirmed in Velbus 7.006
 Current time is 08:34 am
