UCM/Velbus 5.219 is released
 Posted: Saturday Aug 21st, 2010 02:24 am
The UCM/Velbus is now released as firmware 5.219, see attached firmware file for those who have the older version.
This version allows 512 velbus channels to be learned compared to the earlier firmware which was limited to 256 channels. In the older version if a larger Vebus network with more than 256 channels the network cannot be learned successfully and the velbus addresses must be entered manually
Comfigurator 3.2.2 is required to handle more than 256 channels, see http://www.comfortforums.com/forum20/1964.html
However this version of Comfigurator is limited to 330 channels due to a bug. The next Comfigurator version will handle 512 channels
Known Issues
  1. The value of temperature received from the VMB1TS temp sensor is wrong
This has now been fixed in Velbus 5.220
Attachment: VELBUS5_219.zip (Downloaded 9 times)
 Current time is 05:38 am
