Visonic Wireless Sensors and Receivers with Comfort
 Posted: Tuesday Dec 13th, 2011 11:28 am
Visonic has a range of wireless sensors and receivers called PowerCode which can be used with Comfort.
The MCR304 is a 4 channel receiver and MCR308 is an 8 channel wireless receiver which can be hardwired to 4 and 8 zone inputs in Comfort respectively, see http://www.visonic.com/Products/Wireless-Property-Protection/Wireless-receivers
They have a wide range of wireless transmitters which can be used with the receivers
eg
Wireless Detectors
http://www.visonic.com/Products/Wireless-Property-Protection/intrusion-detectors
Personal Emergency
http://www.visonic.com/Products/Wireless-Property-Protection/Personal-emergency-wireless-property-protection
Keyfobs for arming/disarming
http://www.visonic.com/Products/Wireless-Property-Protection/Control%20Keyfobs/control-keyfobs-wpp
Outdoor detectors
http://www.visonic.com/Products/Wireless-Property-Protection/Intrusion-detectors-outdoor
 Posted: Tuesday Dec 13th, 2011 11:29 am
schford
I used these to retrofit some window sensors and the Shed - they work really well.
Take note though - you will actually use up more than just the 4 and 8 inputs respectively. Eg you will want one to show the low battery warning, one to show if someone is jamming etc there are also a cpl of other options if I recall.
Stuart
 Posted: Tuesday Dec 13th, 2011 12:55 pm
TheMax74
Me too. Worked very well.
 Posted: Tuesday Dec 13th, 2011 05:46 pm
Tan121
What about 2-way keyfobs? For that I need both inputs and outputs. Does visonic have transmitter with inputs and outputs?
 Posted: Wednesday Dec 14th, 2011 04:54 am
I dont think there are such things as 2 way keyfobs
The keyfob just sends a signal to arm or disarm
Comfort will indicate armed or disarmed on the keypads, or iphone etc
 Posted: Sunday Jul 15th, 2012 10:47 am
gaylordsecury36
Restricted
Hey Tan,
I think you are little bit confused of keyfob, It sends only one signal.
 Posted: Monday Jul 16th, 2012 07:40 am
Tan121
I am not sure that I understood wrong.
Look at Two-way Keyfob MCT-237.
It says "two way" 6-button???
 Posted: Monday Jul 16th, 2012 08:54 am
Vangelis
This device may only be Compatible with PowerMaxPro, PowerMaxComplete and PowerMaxExpress
control panels - as it states (not Comfort).
I have an old Visonic receiver and it does not have any mechanism to take and input to act as 'status' to feed this back to the keyfob
 Posted: Thursday Jul 4th, 2013 04:00 pm
Somersetdude
Hi Ident
This looks good as i already have some Visonic detectors.
Does the Visonic Receiver need the relay board to connect to the zones on comfort (its described as an open collector to dry contact adapter)?
The spec says the the receiver outputs are open collector type and, as i don't have any add on cards for comfort for digital inputs, i wasn't too sure.
Cheers
 Posted: Friday Jul 5th, 2013 12:43 am
Open collector outputs can be connected directly to Comfort Inputs
You do not need any relay
 Posted: Friday May 30th, 2014 02:17 pm
maka
Hi Daft QuestionBut when using the MCR-308 do you not need a common connection on the comfort channelSo say you connect output 1 on the MCR-308 to Z1 on Comfort how is the circuit made, what connects to the COM terminal on comfortThanks
 Posted: Friday May 30th, 2014 03:06 pm
You need to connect the COM on the MCR308 to the 0V terminal on Comfort. You can also use the Zone Common between 2 adjacent zones
 Posted: Thursday Oct 9th, 2014 06:49 pm
13th Post
DailyProtect
I know a friend who tried this out and realised that it sends out only one signal
 Posted: Wednesday Dec 7th, 2016 10:48 pm
14th Post
Wimphot
As I understand it Visonic is a one way system: sensor to MCR-304. Are there any two way wireless systems that Comfort Alarm users have tried?
 Posted: Thursday Dec 8th, 2016 05:42 am
15th Post
Wwhat do you mean by one way and two way system
Do you mean that the sensor should receive commands from Comfort as well as sending  its status on or off?
 Current time is 01:26 am
