Posted: Friday Aug 1st, 2014 02:46 am |
MDKKEN
Posts: | 38 |
Hi,- I like to use lightwave RF.
- Can I use / combine universal UCM with ETH03 and download UDP proticol as stated in the upgrade needed for lightwave RF comms?
- Do i have to use ETH02 when ETH03 is now here?
Posted: Friday Aug 1st, 2014 07:39 am |
Posts: | 3496 |
Yes You can use Universal UCM + ETH03 for Lightwave RF
Posted: Wednesday Sep 24th, 2014 05:01 pm |
carrington
Posts: | 8 |
I would like to do this - can I just check that I should download the UDP firmware for ETH02 and apply to ETH03 and follow the instructions in the App note?
Thanks!
Posted: Wednesday Sep 24th, 2014 05:46 pm |
Posts: | 3496 |
Eth03 is a different hardware platform from eth02 so the firmware is not interchangeable
Posted: Wednesday Sep 24th, 2014 05:54 pm |
tman
Posts: | 22 |
carrington wrote: Hi,
Thanks!
Use the ETH03 universal firmware if you have an ETH03. The ETH02 and ETH03 are completely different modules and the firmware is not compatible between them.
Posted: Wednesday Sep 24th, 2014 06:18 pm |
carrington
Posts: | 8 |
Thanks that is what I had assumed, it seemed unlikely.
But I am not sure which parts of the LightwaverfAppNote.pdf are applicable? Do I just pickup at the "Comfigurator Programming" (page 9)? If so how do I programme the Wifilink IP address into the comfort? The steps described seem specific to the ETH02 device?
Posted: Wednesday Sep 24th, 2014 07:20 pm |
Posts: | 1200 |
The lightwave RF application note was written for the ETH02
ETH03-Universal 1.15 supports UDP
However there is a problem with Lightwave
They have changed their registration method with their new firmware
Regsiitration was by sending a lighting on or off command from the UCM but now a registration code is required, and that code has changed several times
We will send some instructions on how to go ahead
But it i quite worrying that their API commands have changed without warning
Posted: Tuesday Oct 7th, 2014 02:29 am |
carrington
Posts: | 8 |
I agree that the unannounced API change is concerning however do you have a date when you can expect to release the revised instructions?
Posted: Saturday Oct 11th, 2014 10:04 am |
tech07
Posts: | 106 |
Originally, to register the UCM/Universal to Lightwave, you had to send any command from it while pairing
Now you have to send the string 001,!F*p\n
Add comma "," before any command in comfigurator response, such as turn on room 1 device 1, ,!R1D1F1\n
This was not disclosed by Lightwave, it was detected by using wireshark
Posted: Saturday Oct 11th, 2014 10:08 am |
tech07
Posts: | 106 |
I forgot to say you need ETH03 Universal 1.15 firmware to support Lightwave for eth03
Download from http://www.cytech.biz/eth03_firmware.html
select UDP
For multiple commands into a single response, the correct format is :
!FeP”<sequence name>”=<command>,<delay> ,( <command>,<delay>
eg
001,!FeP"Test"=!R1D1F1,00:00:03,!R1D3F1<cr>
or
