LightwaveRF interfacing, multiple commands
 Posted: Sunday Feb 16th, 2014 11:55 pm
Majik
The UCM/Universal to LightwaveRF can be found at http://www.comfortforums.com/forum94/3066.html
I'm interfacing with a LightwaveRF WIFIlink device. In general it works,but in cases where I have a response with multiple actions, each of which sends commands to the WfiLink, I can see the commands going out over the network with Wireshark but the WifiLink only seems to respond to the first command (with an "OK" response. It's as if the commands are coming too fast, or the WifiLink cannot recieve a new command until the first has been processed.
Is there a way to make these work more reliably? May there's a way to wait until the OK response has been received before sending the next command?
Cheers,
Keith
 Posted: Wednesday Feb 19th, 2014 05:29 pm
The UCM/Universal  does not wait for the OK reply from Lightwave
This is because the Universal UCM is not specifically tailored for the Lightwave wifilink - it sends programmed commands in the list
You can work around by inserting a 1 second delay between commands
using Do Response after x seconds
This short interval should be enough time for the wifi link to respond
 Posted: Thursday Feb 20th, 2014 02:54 am
Majik
OK, thanks.
It might be worth updating the application note to reflect this.
Cheers,
Keith
 Posted: Thursday Feb 20th, 2014 06:08 am
Yes we should certainly do that
 Posted: Monday Feb 24th, 2014 11:35 pm
palmlodge
Keith, I've been asking for a pause command for quite some time. Feel free to add your voice.
 Posted: Sunday Mar 9th, 2014 09:59 am
This has been brought up in the last R&D meeting. There may be a way to implement an inline delay in firmware
 Current time is 01:11 am
