Posted: Sunday Sep 9th, 2012 06:00 am |
Posts: | 3496 |
An Application Note showing how to control the LightwaveRF devices using the Universal UCM with ETH02 can be downloaded from http://www.cytech.biz/lightwaverf_interface_application_note.html?category_id=124
The example cclx file is also available
The Interface requires the wifi-Link used for Iphone/ipad control
One way control from Comfort to LightwaveRF is possible using the UCM/Universal + ETH02
The Universal UCM allows interfacing of almost any 3rd party home automation system with Comfort. This can be ordered with a RS232, RS485 (Isolated) , or Ethernet interface depending on the device to be connected.
The Universal UCM with ETH03 interface is required for LightwaveRF
The Universal UCM can be programmed for baud rate, parity, checksum and other parameters to match that of the 3rd party device. It has a user interface which allows any command to be sent to the device. Commands or messages can also be received from the other device and mapped to Comfort Registers like Counters, Sensors, Keypad keys and Virtual Inputs. However the LightwaveRF product is only one way, ie it accepts commands but does not send status
Universal UCM Interface on the Cytech website
http://www.cytech.biz/universal_ucm_interface.html?category_id=74
Posted: Monday Oct 22nd, 2012 02:17 pm |
Posted: Friday Sep 20th, 2013 11:15 am |
wexfordman
Posts: | 519 |
Just spotted lightwave rf in maplin, and was thinking of gettinga few sockets if I can integrate with comfort.
Is the interface still one way only, or are there waysor plans to make it two way ?
Edit:- Doh! just spotted, lightwave is one way only! Think I will stay away so.Last edited on Friday Sep 20th, 2013 11:17 am by wexfordman
Posted: Friday Sep 20th, 2013 03:08 pm |
Posts: | 4455 |
The Lightwave Interface has to be one way because Lightwave itself is one way, ie it does not send any information back. This keeps their costs down for their DIY market
Posted: Saturday Sep 21st, 2013 12:27 pm |
wexfordman
Posts: | 519 |
Thanks slychiu,
I spotted that and edited the post. Was only thinking about it to try and get a wireless solution to some outdoor shed. I have velbus so might run a few pairs out for it instead.
Thanks,
Eamon
Posted: Saturday Sep 27th, 2014 02:26 pm |
Posts: | 1200 |
It appears the the LightwaveRF API has changed without notice over the last several months
The method of registering a device like Phone or UCM/ETH03 has changed as well as the format of commands to the API
We have not received any reply to requests for technical information so far
We do not recommend any new user to try to implement the LightwaveRF interface via Universl UCM with ETH02/03 until this is cleared up
Posted: Sunday Sep 28th, 2014 06:14 pm |
MDKKEN
Posts: | 38 |
From the lightwave forum
I am using it with Crestron. I have fixed it Wednesday (17.Sep.2014) by adding ā100ā³ in front of every command.All you have to send is ā100,!R1D1F1\x0Dā and it works fine. No need to reregister or change anything else.
hope this help
Posted: Monday Sep 29th, 2014 08:00 am |
Posts: | 4455 |
Yes, we also found that out, but it is worrying that the API can change without notice
This can cause a lot of support issues especially if it happens again
Hence I suggest that those who are considering Lightwave with Comfort should be cautious
Posted: Tuesday Dec 9th, 2014 02:26 pm |
palmlodge
Posts: | 479 |
What's the current thinking with LightwaveRF. Is this a viable extension to Comfort or is ZWave preferred?
Posted: Tuesday Dec 9th, 2014 03:01 pm |
Posts: | 4455 |
There is a bit of uncertainty about Lightwave, with these unnanounced changes in the API. We are not able to contact them unlike when we first started working on the integration, so I would not call this a viable option at this time.
Posted: Wednesday Dec 10th, 2014 03:09 am |
palmlodge
Posts: | 479 |
It amazes me that that we still don't have just one product that is a viable retrofit.
My CBUS system has been in place 10 years and is rock solid, but it isn't cheap and I don't have their Wireless plugin modules.
Time for Cytech to come up with something? :-)
Posted: Wednesday Dec 10th, 2014 09:05 am |
Posts: | 4455 |
You know what is the best way to make a million dollars from manufacturing Lighting control products??
Start with a billion
Posted: Wednesday Dec 10th, 2014 05:37 pm |
