UCM/Zwave 7.062 Beta
 Posted: Friday Dec 5th, 2014 09:00 am
UCM/Zwave 7.062  (beta) has the following change
The timeout during the learning process for query of a zwave node has been increased from 8 seconds to 70 seconds. This may help prevent situations where UCM/Zwave is unable to detect a multichannel device which results in it being assigned as a Basic node.
This may happen due to  Zwave network issues
The increased time-out does not mean that it will  take longer to learn a zwave network from the primary. It means that if there are nodes which do not respond at all, the learning may take longer. Nodes which take longer than 8 seconds to reply will be learned correctly
 Current time is 12:23 am
