Posted: Friday May 5th, 2017 02:22 pm |
Pharris15
Hi, I have some contractors working and I want to bypass 3 garage doors and a PIR, I thought that the response attached would work but it only bypasses the first device.
Any help appreciated.
Attachment: BypassGarExt.pdf (Downloaded 5 times)
Posted: Friday May 5th, 2017 02:50 pm |
Swiss-Toni
In what mode do you want them bypassed night day away (tamper)
Simple way would be to change the settings for that zone disable the zone completly
Posted: Friday May 5th, 2017 02:57 pm |
Pharris15
Hi, thanks for the reply, I have set a schedule to bypass at 07:00 then unbypass at19:00.RegardsPaul
Posted: Friday May 5th, 2017 03:08 pm |
Posts: | 5495 |
that response should bypass the 4 zones
Try Executing the Response directly from Comfigurator in the Response menu
Do a Security Check on the keypad F3,2 to hear the announcements of open zones
Then Open the zones and move in the PIR area. When bypassed the zones should not be announced in Security Check
Execute the Unbypass Response and do the security check again if you have exited the security check mode. Now the zones should be announced when opened
If you are testing the time program by changing the time note that you have to set the time before the programmed time, eg 1 minute vefore. You cannot change the time to after the programmed time otherwise the Response will not be executed
Posted: Friday May 5th, 2017 03:15 pm |
Pharris15
Hi, I have tried executing from the response menu but it only bypasses the first in the list, all others announce.See attached. Attachment: Bypass response 1.pdf (Downloaded 4 times)
Posted: Friday May 5th, 2017 04:04 pm |
Posts: | 5495 |
There seems to be a problem with the Execute Response for Bypass zones
You are correct that only the 1st zone is bypassed
The same with execute response of Unbypass zones
However if the response is excecuted by the system eg by Time programs then it works so I believe tit will work in Time programs
You can also use the Do Response command R!NN where NN is the Response number in hex. This wil work becvause it is doung the response instead of the individula actions via DA...
We will check why this bypass actions in sequence do not work
Posted: Friday May 5th, 2017 04:23 pm |
Pharris15
Hi Thanks for the update, I have just tried it by setting the timer ahead and it does function OK.
Posted: Wednesday May 10th, 2017 07:45 am |
Posted: Friday Jun 9th, 2017 11:01 pm |
Pharris15
Hi, I have noticed that even though the bypass is set from 07:30 until 19:00, if I return home and disarm, then go out and rearm; the bypassed zones have been unbypassed.Is this supposed to happen and if so how can I force the bypass to remain operational until the end time is reached?
Posted: Saturday Jun 10th, 2017 06:04 am |
Posts: | 5495 |
A Bypassed zone will be restored ie become unbypassed when the system is disarmed
If you want the zone to remain bypassed when the system is disarmed use the Omit action.
Only Unbypass action will work on an omitted zone
